Hooking up Heater
Loose Deuce
South MS.
Does anyone know how to wire up the on/off switch for a heater? I'm hooking up a mutt Jeep heater in my Deuce and it didnt have any instructions with the kit. Wiring up the power is what I need, it has a Hi and Low and Off toggle switch. That ceramic piece with the wire thats coiled around it, where does it go ? I'm not that good with electrical wiring and componets :confused: Where could I get a wiring diagram? :shocked:
MVtrucker
Bridgeton, NJ
Easy one. Lets designate the switch posts as follows: A. Center B. High C. Low Speed. Hot from circuit breaker to center post A. Mount the ceramic resister in an open area, like on the firewall in engine compartment. Run one wire to B and the other to C. Attach the heater motor's wire to B (now two wires on post B). If I remember correctly, when the toggle is flipped to the B side, it will be on Low Speed. When flipped the opposite way it'll be on High. Double check this before mounting the switch and data (if it has one) plate. The way the switch works is when switched to low, voltage from A goes to C and the resister then back to switch Post B and motor. When on high, voltage goes directly from A to B to motor. I can send a sketch, if needed.
