cllctrtom
- 0
- 6
- Altoona, PA
Can someone tell me why my horn stops working when the air pressure goes above 60 PSI? In PA, I need to use it often. Thanks in advance!
Thanks Bad.... I'll give it a try!Squirt some WD40 in the air line leading to the horn. That may help.
Another idea I will try. I had no idea about the adjustment screw. Thanks!maybe the diaphram in there is too tight. they have adjusting screws on the back of the horns, you could try adjusting that when your air pressure is up and see if it works. just an idea.
