If it's just to prevent pressure build up, height or lenth shouldn't matter. I'd think rerouting it into the intake side would be better as there could be some gases in the tube that would possibly add a smidge of power. Seems like venting it to the exhaust side could possibly add a bit more smoke or oil build up in the pipe.Im planing on using the deuce for many things and one of thoes things is offroading and probley through some water will it suck water up the tube? and if it does how high can a get the tube before it stops doing its job properly
you pull the fuel stop handle, fuel is cut but you are still producing vapor for a quick period before shut down and this gets sucked in to the intake and poof she will fire back up because by now you have pushed the full shut off handle back in.
