How best to power/wire a 2 HP Hydraulic Pump to my M1009?
rceldib
Los Angeles
I have a 13 Gallon Per Minute Positive Displacement Gear Pump which I want to drive with a 2 horsepower 12V DC motor that is rated at 69 amps. I am using this as a Waste Oil Collection Pump so I would be running the pump for a maximum of 10 to 20 minutes. Can I power this from my M1009. If yes, what is the best way to wire it into the truck and what size wire should I use? Thanks!
richingalveston
120
galveston/Texas
if your still 24v then you will have to conect it to one battery.
In the DC world. amps X hours = AMP/hr. 1 amp for on hour equals 1 amp/hr.
69 amps for 20 minutes is 23 amp hours.
check your battery rating and it should give you the total amp hours available. most are 90 to 100 amp hour or more. thus if your truck was not running, your drain on the battery would be between 1/4 and 1/3 of the battery reserve power.
so yes you could run it on one battery with truck off for 20 minutes and probably still be able to start your truck.
If the truck is running then you should not have anything to worry about unless you had a lot of auxilary things running that would use up your 100 amp alt. output.
Wire size will be your only issue. make sure you size the wire to handle the load. don't have my wire calculator handy but 70 amps at 12 volt will require a decent piece of copper. by the way, you also have to figure wire length when calculating wire size since it is DC. The longer the leads from the motor to the batt. the larger ther wire needs to be. Using to small of a wire will cause low voltage on the other end thus making a short life out of your pump.
