How to install s3 smart start
Dsc45shooter
Ky
Is there a guide on how to install these anywhere? As far as i can tell you unhook the batteries, swap out the box under the dash with the new one, swap out temp sending units with the new one, and then reconnect batteries. We have yellow label nartron eess boxes under the dash right now.
gcbennet
Trenton, ON
I use dialectric grease on all of my plug connections. The big thing with the S3 box cannon plugs is to make sure the one in the engine compt has a good coating on top where the wires pass through the rubber. The plug sits vertically, and if there's any age cracking in the rubber seal at all moisture will seep in with gravity and corrode the pins from within.
