How to raise the metal top on a M105A2?
bayoufisher
Baton Rouge, LA
Before I waste time trying to come up with the best/easiest solution, I thought I'd ask if anyone has already come up with a simple way to raise the metal top on a 105A2. I want to be able to quickly raise it after I trailer it, so I'm looking for a system that is fixed to the trailer. I'd appreciate any information from your past similar project.
gimpyrobb
dumpsterlandingfromorbit!
27,786
752
Cincy Ohio
What distance does it have to travel to be all the way up? I have a high volume low pressure hydraulic pump and some cylinders that could work.
rchalmers3
30
Irmo, South Carolina
My first answer is that I don't have an answer to your question.
My second answer is that I have a tool made by ARB of Australia. It's an air bag about 28" in diameter and 2" thick deflated that will lift the weight of a car with very little pressure. It's designed for situations where your highlift jack cannot be used due to soft earth.
It wasn't too expensive and you might consider it for a solution that is outside the box.
Rick
bayoufisher
Baton Rouge, LA
Rick
I know the bag you're describing. That's a different thought. Thanks!
Crawdaddy
Louisiana
I believe there is a jack that's supposed to go with the box to lift it up. It's essentially a floor jack with a long pole that latches to a spot in the center of the roof that picks it up. There's a recent thread of another guy with a box like that.
amaverick88
Bonaire, GA
Are the air lines still hooked up on the trailer? If so you can use air actuators to move it up and down once you are in position. That is if you are pulling it behind a deuce or another vehicle that supplies air. If not you have the options to use elecctric actuators as well.
LowTech
151
Arizona
That's correct. The top of the jack has a channel that fits the ridge beam. Once it's jacked up and pinned in place the jack gets removed.
I sure would like to come up w/ an easier way to do it, . . . like hydraulics in all four corners ;)
I can take some photos and post up tomorrow . . . been meaning to do that anyway, I'm turning it into a camper.
LowTech
151
Arizona
Ok, this is what the jack looks like.
And this is what mine has in the corners,
gimpyrobb
27,786
752
Cincy Ohio
If you can find the piston, I have hydraulic pumps like the one pictured, and dual stroke ones. Should be easy to complete.
