How to remove a piston through the exhaust port
Kaiserjeeps
North Idaho in the woods
I had a blown head gasket. Removal showed my rear head on my 69 kaiser M35 had cracks in all cylinders. I found two new style heads (they have a valley between the valves verses flat) and found they had a problem. The first one was mouse related. Lots of pee and corrosion in several intake ports completely stuffed with millions of seeds. A little phosphoric acid and it was fine.
The exhaust manifold came off and there poking up out of a port was a bunch of sooty aluminum. The cylinder surface was beat to heck. I could not look close since it went from bench to truck quick on a forklift.
Kinda funny. Never assume it is ready to run. Not sure why I don't get pictures. I have the IMG in the edit mode but still shows a link in real time.
The machinist found some pretty big issues. I am glad I took in my cracked head for some donor valves.
The finished cylinder. This guy is great. He said he picked aluminum out of the port walls with a dental pick.
Now I need to install them.:jumpin:
Stalwart
33
Redmond, WA
I saw an RD400 2-stroke mororcycle do that at night. He as going 75-80 mph and the sparks were 150-200' long. The piston lasted about 30 seconds . . .
Kaiserjeeps
I don't know Gimp. But it keeps the heads from cracking. Recovery4x4, My motor was fine except the head gasket and head cracks. I had not planned on anything else. I just did a rear main, all new clutch. I had all the intake and exhaust off a while back. My LTD is a good sound motor. It actually pulled and ran well. I want to get it running strong again and then swap in my LDS.
Warthog
232
OKC, OK
Sure looks like the mouse was chewing on the valve. Must be one tough mouse.....:mrgreen:
