Loose Deuce
- 0
- 0
- South MS.
How can you remove the fuel pump that's on the side of the Injector pump while the injector pump is still on the motor ? That steering column at the steering gear box is in the way. I took the 4 bolts out where the column mounts the gear box, but it wont come out and I loosened the column in the cab too. how is its supposed to be removed ?
