How To Wake-up a Mothballed CUCV?
NMC_EXP
12
Raton, New Mexico
I'm getting the urge to buy an M1009.
Looks like GSA sells a lot of them. However it seems most of the GSA units have been parked for at least a year before being auctioned.
What items are the "pre-flight" checklist for an M1009 which has been parked and dormant for a year or two?
Items I can think of are:
  1. New batteries
  2. Check engine oil for presence of coolant or fuel
  3. Check coolant for presence of engine oil or fuel
  4. Check driveshafts for forklift modification
What if anything should be done before firing it up for the first time assuming prior maintenance records are not available?
I've never owned a diesel powered vehicle. The only MV I've owned was an M37B1 so any suggestions you have on how to bring an M1009 out of hibernation will be appreciated.
Regards
Jim
WillWagner
2,617
Monrovia, Ca.
Hoses,belts..if you're gonna attempt drive it at all, M/C, brake fluid. Member, it's gonna be BFS NOT regular off the shelf stuff.
1,176
Some might say, best to let sleeping dogs lie....
CARNAC
The Envelope Please.
631
Corpus Christi, TX
Sound wisdom, but I don't think my 2.7L Tacoma would handle it.
Thats part of the reason I'm interested in a M1009 - being able to tow a couple of tons once in a while.
If you think the 1009 is gonna tow a ton of stuff, you're incorrect. I have towed 3100 pounds of mulch before but that's maxing it out .
reloader64
137
Liberty Hill, Texas
It depends on how far you have to drive it to get it home. Hoses won't rot in a year, unless they were bad to start with. Belts, maybe. Diesel fuel won't go bad in a year, unless it was already contaminated. The tires may be old, and sitting in the sun they will tend to dry rot. I have some mechanical ability, and some very good friends, so if it was me, I would probably try to drive it home, if it wasn't too far. Having said all that, if you know someone with a truck and a car trailer, that would be the easiest way.
Scott
jumpmasterjim
NY/NJ
M-1009s wheel base is short and care must be used when towing with them, When I was stationed in Germany 86-87 we were not allowed to tow anything with the M-1009s.
hovenga67
Evansdale/IA
I have towed a 2000 pound car trailer with a 4000 pound 66 Olds toronado on it with a s10 Blazer with a 2.8. So I would hope you could do the same with a full size. As long as you are carefull and load you trailer right you should be able to do what you want. As far as picking it up. I would take a tool box full of tools, some diesel kleen additive, jumper cable, probably get extra belts and bring them with, also all your basic fluids. I don't think I would do it without a decent chase vehicle. Oh yeah better bring some spare tires.
Brent
kassim503
Stony Brook, NY
Honestly, id rent a dolly/ tow bar and slug it home. The chances of it firing up on the spot is slim to none. But if you do decide on driving it home, id bring lots and lots of batteries, bleed the injector lines at the injector, pray the glow's work, and if you get any thumps keep the throttle down at high revs for a minute or two after at high rev's. Then pump the brakes and ensure a good pedal feel and slug it home in case that dent in the driveshaft feels like getting bigger!
