Humvee seat pad question
Sadistich0rr0r
Vancouver washington
I’m stuck waiting for my Humvee paperwork and am trying to plan ahead by getting some stuff I’ll need. Does anyone know if the bolt pattern is the same all around for the passenger seat pad and passenger back seat. Also if the rear seats and seat backs are the same pattern and the same as the front? I found a good price on seat pads for the rear and figured if the bolt pattern is the same I might just use the seat bottoms for the backs also and the pass front back and base. Any thoughts?
cwajciec
Richmond VA
I did this exact thing and use all seat bottoms for the 4 rear seat pads. Bolt pattern is the same although the bottoms are a little thicker than backs so when you fold the seat down you have to compress to get it to lay flush.
I went with the ones on sportsman’s guide and they work nicely.
Sadistich0rr0r
Excellent, thank you. I will order some now then but do you happen to know if the pass front will take the same bolt pattern? I’d like to use them for the seat and back there also. I ordered 6 total, i hope they fit but if not its nothing a drill cant fix :)
Action
1,557
East Tennessee
There are a lot of thin reinforement ribs under the battery compartment, but you could just move thd cushion a bit if needed.
cwajciec
Richmond VA
Yeah I took a chance on sportsman’s guide and they look fine to me. Not sure if these are mil spec or anything but the canvas is thick and the right color. I think I paid $30 for 2 cushions with free shipping. Seat bases are another matter. They are hard to find and I ended up making one out of sheet aluminum after buying one as a template.
rolling18
75
Portland, OR
sory just found this and need seat cushions!! do you have a link or description? I cant find them on that site anymore..:(
thanks!
