Humvee Stanadyne DB2 Injector Pump bulletin
papakb
1,185
San Jose, Ca
I clicked on the link Suzucovich posted and had no trouble downloading the file on the Stanadyne pumps. It comes from a site called linksharing.samsungcloud.com. It's the most comprehensive listing I've ever seen on these IPs and they mention "supersession" a couple of times in the pdf. It's not a term I've seen before and I wondered if anyone knew what it means in relation to the IPs.
Here's a copy of the first paragraph of the file:
The pump models, applications and supersession information for General Motors
(GM) 6.2L & 6.5L engines from 1982 to 2000 and General Engine Products (GEP)
6.5L engines from 2000 to present are identified in this bulletin. If a pump model
listed does not display any supersession information, it is considered the latest
pump model for that application
suzukovich
141
Gibsonton Fl
3&4 TM list only 4 pump models by NSN one for the early 6.2. and can only be used on the 6.2. Then different NSN for IP for later 6.2 1990 and later. Which also can be used on the NA 6.5. Then you have the IP pump for the 6.5T GM,and 6.5T GEP. The NA 6.5 GEP had a separate NSN and was marked Detuned. So it probably means some of the other model pumps can only be used on those engines. Like I said the pump I have on mine is the same on the FMTV Cat engine thats Tubocharged. And is an authorized substitution.
Sent from my SM-J727U using Tapatalk
snowtrac nome
138
western alaska
Am I reading something wrong how can you make the cat pump from a 3116 or a 3126 work on a v8 gm diesel the operation of the fuel systems is totally different.
86humv
498
Texas
Nice list.
Here's some updated info :
DB2831-5079 is 6.5 turbo,...new # 6282
DB2831-5209 is 6.5 De-tuned,...new # 6278
DB2831-5149 is 6.5 NA , ...new # 6277
Milcommoguy
2,261
Rosamond, CA
Supersession > Fancy word for replaces, supersedes, new and improved. Person, product, process, etc. Hmmwv A1 to A2.
From flip phone to IPhone to...
Beam me up, Scotty.
CAMO
4x4Junkie13
26
13
La Vernia TX
After looking through this bulletin, I am left still wanting for a more complete list. Is there a comprehensive IP number list? I have seen many more pump numbers used especially for 6.5T engines in the REV B series.
