Hydraulic Crane Wrecker Specs
Cowlhoods
Valdez Alaska
Can anyone tell me the PSI/GPM of the M816 Crane Wrecker Hydraulics. I need to tap into the existing lines for my additional winches. Has anyone converted the garwood 10,000lb winch? Any help would be appreciated
Patrick
Cowlhoods
Valdez Alaska
Can anyone tell me which way the shaft going into the tortet goes on the crane wrecker? I finally am getting somewhere on my project and need to know what rotation for my PTO on my 1241C auxillary. Also let me know in reference to which way you are looking at it . Ref: from the seat or looking twards the rear from the front.
Thanks again
Patrick
1,128
I can't help you Patrick but we'd love to see some pics of your project.
Cowlhoods
Valdez Alaska
here is a pic from this summer when we were adding the Zacklift. The downriggers are independent and will be reinforced pads with ice grips, etc. Three D-Rings will be welded on each. We added a Warn 12000lb hydraulic winch to the outrigger base up front for a sidepuller, with the same three d-rings down them each. We are making a stand for the boom to rest on that will have a boom head swivel for the 45k winch out the back. I still have the factory stands and the factory fairlead out the back. I also have the factory driveshafts left as I went hydraulic on the 45k. hyd motor alone was 975.00 out of Florida.
BUT I really need to know the rotation of the shaft going into the crain as you are looking at the rear from the tranny side so that I can have this thing on the road in a few weeks and post some action pics.. That is the only thing holding me up from my crain working
Patrick
