Hydraulic Oil, can you use it is fuel?
xmission
NH
Looks like I'm going to have a couple of hundred gallons of #32 hydraulic oil that I'll need to dispose of.
What do you think?
cornrichard
Galesburg, IL
I had 40 gallons of IH hytran that got water in it. It turned pink, Hytran absorbs water. I fed it to the deuce and it loved it. I mixed it at 2 gallons diesel to one gallon Hytran.
Jake0147
Panton, VT
There are some fire retardant ones out there, I'd avoid that. But if it's plain old AW-32 then it works quite well. If it's out of a mobile application make sure you filter it first. But yeah, good stuff...
63sierra10
Worland, Wy
I am lucky enough that along with some semi trucks we bought we also have a fuel WMO filtering system that works well. You put one hose into the WMO and one hose into the fuel tank for suction and the third hose is the returned filtered and mixed fuel. Works great for the old deuce.
wdbtchr
St. Louis, MO
Let you in on fire resistant hydraulic fluids(Like Skydrol for aircraft) it still burns. Thats how we used to get rid of contaminated fluid, burn it in the boiler to generate steam. It' is fire resistant, not fire proof, you should see it burn.
The best reason not to use it is because it will cause regular Orings to swell up.
xmission
NH
Thanks all.
This oil is standard 32w, out of an elevator application. There was no contamination, and it's only being changed due to a contractual obligation. We do this sort of thing fairly often (at least a couple of hundred gallons a year), but I never had a deuce , and we've actually paid to get rid of some of it!
I do have a really good filter pump if we ever run into some contaminated stuff.
Dan
xmission
NH
From time to time we run into an application where they want fireproof oil. We have not found an oil yet that works for this.
There are systems out there that run on water.
outsider
Western Michigan
Look for a product called "Water Glycol Oil" it is used in aluminum and zinc die cast machines and is a water based hydraulic oil, and no matter how hard you try it will not burn. It will work in any standard hydraulic system and is red to pink in color depending on how much water is in the mixture.
Steve
xmission
NH
Steve
Interesting. I'll look for it.
Ferroequinologist
Resident railroad expert
736
Liberty Hill, SC
Steve
I beg to differ- we used water glycol oil, and it may have just been the additives in it, but if a hose blew on the steel furnace where I used to work, that 3000 degrees would make it burn a bright blue- and that is on the outside of the water cooled panels!
I still think you are right and it won't burn under normal circumstances.
I burned some used hydraulic oil in the deuce last week. Loves the stuff. BTW- might want to check you state laws- after the thread on the fella in NC getting pulled and fined for WMO in his tank, I found out SC requires a fuel blenders license. I now have one, easy to get and free. If I ever get pulled, as long as I don't have off road diesel in the tank, I just have to show my blenders license. FYI
I wish I could get a few hundred gallons of used hydraulic oil a year!
xmission
NH
That's interesting. I didn't think about that.
airmech3839
Augusta, GA
Ferro....when they dip your tank if it has a red tint they wont believe you will they?.... I am in the process to get a GA blenders licenese... If you want to get rid of that oil I would love a couple a 100 gallons....
Tracy
Ferroequinologist
736
Liberty Hill, SC
I don't want to take that chance. I currently don't burn ATF for that reason. I believe I could have a lab test it and fight it in court if I was 'caught' burning ATF. But I would rather not go thorugh the hassle.
