I am looking into removing the govenor!
TigerHawk
Small Town USA
I'm looking for information on the proper way to do this, and does it just let the rpm run out or does it allow the engine more power?
The engine is a 1971 Herc LDT 465 Multi-fuel.
Thanks,
avengeusa
MI USA
DO NOT DO IT!
unless you like the idea of seeing a rod hanging out of the side of the block sooner or later, probably sooner
the guvna is located in the injector pump
Keith_J
1,319
Schertz TX
Second. It protects the engine. They don't like spinning too fast You might increase the spring tension to get higher RPM but anything over 2800 is asking for problems. Any fuel/RPM mods requires an oil cooler, PERIOD. Direct injection diesel pistons need all the oil cooling they can get since the "fire" is mostly in the piston and the only way to deal with the heat is an oil jet. Put too much heat in there and the pistons run too hot, turning into taffy, then seizing and throwing a rod.
Before you think of adding performnce, learn about DI diesels.
TigerHawk
Small Town USA
I'm just looking for more HP NOT rpm. We have a lot of mountains here in Colorado. I know all about spittn rods, don't want to go there! There must be a way to boost torque! Even the old deisel tractors can produce huge HP with a turbo upgrade. I would thing someone has done this successfully!
combat32
106
Booneville AR.
Not picking on you brother, it is just bad mojo, govna is there for a reason, roll down the window and enjoy the ride, leave early if you need to get there faster:-D
rosco
30
Delta Junction, Alaska
I don't agree, Numbers! Just go ahead and take the hood off. It won't be needed again anyway.
Seriously, everybody wants to make a race car out of something closer to a sled. Rigged right, it would move your house without a hitch, before it would do 70.
Lee in Alaska
Keith_J
1,319
Schertz TX
How about a 5 ton IP? More torque? That is from higher cylinder pressures which mean higher piston temperatures. And the pistons are a bit different.
Now you could intercool it BUT the turbos used are pretty much in their "eye" meaning there isn't much gain here.
TigerHawk
Small Town USA
My point of reference is when I went to a tractor pull and these guys had OLD John Deer and massy tractors with huge turbos and OMG, the performance was incredible! The way the Military built these vehicles , you would think they have some room to play! If I have to I'll buy another motor to experiment with then so be it! But I have to find out what they can do. I'm looking for suggestions from those who have the same sick requirements!
Cheers,
TigerHawk
Small Town USA
Qwest for POWER!
Cheers,
OPCOM
27
Dallas, Texas
you can add a pyrometer before the turbo. Then you can turn up the fuel. It should be OK at 1100 degrees EGT. But don't expect it to go howling up the hill, it's not made for it. If you want that, you need a different engine and it is probably less expensive to put a dodge cummins pickup motor in there than try to re-engineer the multifuel. BTW the transmission is also a weak link for hot rodders.
m16ty
218
Dickson,TN
Cheers,
Those tractors can produce huge HP for short periods of time. Hook them to a plow in the field and you'd be lucky to get one round out of them. They are only built to run about 300' and cool down. Some don't even run coolant. They blow up a lot of engines also.
I know a guy that has a Dodge Cummins pulling truck. His EGT will get up to over 2,000 within the length of the track but because it's only for a short period he hasn't melted any pistons yet.
Just get you a pyro and turn up the fuel a little but don't expect huge gains.
Cheers,
I guess the answer is to put in one of those OLD John Deere engines.
This engine is a 50 year old design. If you were to invest the time and money that the pullers put into their engines, find and re-engineer the weak links, you probably could get incredible performance too.
