I keep slipping out of 4HI ?!?!
edpdx
75
Oregon
I just got back from a 7 day hunting trip. The first time I shifted into 4 HI, I would go a few yards under small loads and the Transfer case (TC) would make a loud grinding noise and then sound as if it were free wheeling. I would slow and place it in park and then shut her down. Upon restarting, it would be fine in 2WD, until I again attempted to crawl along, then it would slip out again. Otherwise it works as expected in 2HI or 4LOW.
I took it to a shop and the guy was able to swap it out for a recent rebuilt NP208. It too slipped the exact same way and only in 4HI. I finished my hunting trip in 4LOW.
What could the problem be?
sf38a1
NW Florida
I had a dana 24 that slipped out of 4 hi, it was a worn gear. if the gears get worn it puts an angle on them that causes them to jump out when a load is put on them .
edpdx
75
Oregon
I took the Blazer back to the mechanic and he went for a test drive with me. We hammered it all to h3|| and could not get it to repeat. I did some googling on the matter last night and got some info on it. Many said that it may well be that the cab/shifter linkage may be banging against each other and to adjust the linkage as per the -20TM.
I'll start there. if that is the problem, I'm just hosed for the money ($1300)- I hate repairs like this when you are on a road trip.
The worse part is that the mechanic seemed very knowledgeable and sincere; but could not have made the adjustment before selling me the rebuilt he had handy. :whistle:
