ignition switch question:
edpdx
75
Oregon
Read applicable threads already; but no help so far.
I have been chasing a "No Crank" problem for the past 48 hours. Ran wiring down as per TM. The situation is: Turn the key. All the requisite dash lights come on and cycle. All I hear is a click. Batteries checked, starter checked. Reminds me of an ignition switch I just changed on my Daughter's El Camino.
Q: If I am getting dash lights, could the ignition switch still be the problem? I pulled it; but did not know how to test it. Cleaned the contacts, but still no go. Anyone know of a way to test this component?
Jtspendy
11
Vineland NJ
when you say batteries check did you test voltage or amps? A battery can have a bad cell which will allow voltage to look good but you loose all your cranking amps
edpdx
75
Oregon
I am not sure how to test amps... Is this what a "Load Test" does?
I checked voltage at the purple wire at the starter solenoid per TM -20's Malfunction test #42. I got a reading of 19.5Volts. Is this too low to crank the engine?... even a little?
edpdx
75
Oregon
ralbelt, I read that already. In my OP I state that the batteries were checked- I didn't mean I checked them and they were dead. They each showed 12.55 volts. That seems like enough to crank the engine over, yet I am only getting 19.5 volts at the purple wire at the starter solenoid. I am looking in the forums now to find out if 19.5v is enough to crank the starter.
mistaken1
Kansas City, KS
If each battery is 12.55V then the purple wire should have something close to 25.1V.
A bad connection (high resistance) can cause a voltage drop when current flows.
Bad batteries will do that (need to be load tested to know for sure).
I have seen others with a bad cable that links the batteries together. When a load is applied that link has a high resistance and the truck will not start. The terminals look good but the cable itself is corroded.
