Kharville
- 0
- 6
- Clinton LA
I recently performed fuel filter replacements on all my fuel filters. After changing them the truck would not start. I found the lift pump fuse blown. I replaced the fuse and it blew again. I took the pump out of the tank to troubleshoot. I submerged the pump in a bucket of diesel and connected 24V. It pumped fine. I reinstalled the pump in the tank and did some troubleshooting before inserting another fuse. The single black wire that comes from the fuse cap seems to be the +24v. That wire has continuity to ground(the mesh wire surrounding the black wire to the pump). I don't think that is correct. It seems the mesh wire around the single wire is ground and the inner wire should be voltage. Are these prone to shorting out? I did not have a short when the pump was off the mounting rail.
