CHIEF_919, unfortunately, there are a lot of guys in the drive-em-out club on this site. I agree with you wholeheartedly...better to get them hauled. I always factor in shipping when determining if I can afford a truck. If the cost of shipping a truck puts it out of my range, then I don't bid...or I look for a truck closer to home.
Yep.
I have seen a whole front wheel, hub and brake drum come off and go into oncoming traffic. I have seen a rear tire shred and the parts hit a passing motorcyclist. I have seen oil line rupture and leave oil on the road causing vehicle behind to skid and wreck. I have seen front tires blow out at 55 MPH. I have seen many brake failures.
All of the above I have seen on in service, maintained vehicles. Your average DRMO vehicle was well used, likey sat at the unit unmaintained before it was turned in for many months and likely had bad parts swapped for good. Then it went to DRMO and sat another 3-6 months before being sold, and all that time was subject to parts swapping. The risks are much higher on a fresh from GL truck.
On top of that, it is the fact that it is being driven off without a valid registration, tags or title that will really sink you should something happen. An accident is just that, but add the circumstances that you are driving a salvage truck off without a valid inspection, tags or registration and if the law does not hang you, the civil suit certainly will. They will sing that to the jury and the jury will eat it up.
If you don't believe me about the lawyers, go back to the old Mil-Veh archives and look for the case where a scumbag lawyer actually went to court and claimed that an m1009 owner caused an accident where another driver pulled in front of him because he had a camofluage vehicle, that was designed to make it hard for people too see, so it was the M1009 owners fault his client didn't see him and pulled out in front of him....
It would be risky enough if you were driving off with valid tags. But without, you just added a whole new huge level of risk to the equation should things go wrong....
