injection pump help
spencer p
ellinwood, ks.
Guys I need some advice. I have 2 deuces that have injection pump leaks. the first leak is the govener spring cap on the rear. can I replace the gasket without removing the pump, and how far will the spring fly out? the next is the Quill shaft cover (laying on the ground looking up at the bottom of the pump it has 2 bolts in the cover with safety wire.) any suprises here? and the last is the control lever for the throttle, I believe the gasket and o-ring are leaking. they all look easy enough, but can they be done in the truck? does any body have a good source for these gaskets?
gimpyrobb
dumpsterlandingfromorbit!
27,786
755
Cincy Ohio
Do you have pics? If I am seeing what you are saying, you will have minor oil leak out when you take them apart. I doubt any springs will fly out.
1,177
Maybe his engine oil is dilluted with fuel.
spencer p
ellinwood, ks.
I will post some pics, I dont have a dilution problem, these passages are specific to engine oil only, they have been leaking for a long time just need to be fixed.
moriboy
22
SW OR
For the rear cap, it's simple to replace that gasket witout removing the pump. There is a spring, but it is really managable to remove and re install. I can't comment on the rest of your questions.
The gasket set for the pump is around $30. I got mine from Eriks Military Surplus, Part #5702663
thehaas
matamoras pa
mines leaking same spot dont think can get rear cover off in truck seems bolt behind things when i turn on fuel pump with truck off mine leaked got pump out and think going to get gov rebuild.then take old one apart.what do you guys think of gov rebuilds .some trucks have diff inner fenders pumps right against it i cut out with grinder and will have removable cover will have to drop steering box to clear upper bolt when sliding pupmp back
gimpyrobb
27,786
755
Cincy Ohio
Wow you need some punctuation. The IP can be removed with those old gasser fenders, no it ain't fun. If you can get a gov rebuild, GO FOR IT. Should be zero worries with one of those.
thehaas
matamoras pa
injection pump
finally got injection pump out when engine off fuel pump on deisel leaked out govenor housing gasket at bottom.washed off stared at it ,understand what every one said about fuel density comp .basically if compensator developes leak internal it leaks fuel into govenor housing part of pump.also i think it adds presure to govenor housing by fuel pump spraying right inside.mine only leaked when fuel switch on.i will take lots of pictures so when completed it helps others out.
thehaas
matamoras pa
question that popped in my head fuel compensator on injection pump do they make cover so you can leave off all tegether or does the bottom fork need to be there even though its disconnected .
gimpyrobb
27,786
755
Cincy Ohio
Some pumps do not have an FDC with just a plate instead. I have not gotten one to be able to compare the two, sorry I can't answer your question.
thehaas
matamoras pa
got a pump from ken kublo ,this one has a cover plate over where compensator went.pump is brand new never rebuilt very nice.two questions i have if anyone can answer first since pump has cover droop adjustment is only adjustment how should that be set.second question do you leave injection pump shaft nut loose and after timing marks are set then tighten nut then three bolts on gear.what do you think torque is on nut and three bolts also would you guys lock tight these bolts.thanks everyone for input
thehaas
matamoras pa
injection pump
ok found injection pump at kublos surplus brand new not rebuilt,where fdc was it has cover now so with fuel density comp eliminated only has droop adjustment how do you adjust droop adjustment.second question when reassembling should i leave nut loose on end of injection pump time every thing then tighten shaft end the three bolts that go through slotted gear ,and should blue lock tight be used.
