Hello,
The 1986 M1008 I have starts then dies after a 3 day sitting. It will start up and run for a second and then die. It will then crank and crank and be hard to restart. i suspect the injection pump is sucking air. I have checked the mechanical fuel pump for bleed down, the rubber fuel return lines and caps, all seem ok. Anyone have a similar problem with the injection pump? I convert these trucks into wildland fire trucks. We have a endless supply of them. I am new to the 6.2L diesel. Thanks
