bigmech
- 0
- 16
- Potterville Mi 48813
I left my truck sitting all winter without a main fuel line and now I'm having a hard time priming the injection pump. I found a small bleed bolt on the side but it still won't bleed out very well ( the lines open at the injectors after bleeding the pump won't bleed through ) Help? I have fuel to the pump and a little fuel comes out of the bleed bolt on the pump. I don't know if I'm doing everything I need to do to bleed the injection pump?
