tuckerj84
- 7
- 3
- Denver, CO
I could use some help diagnosing a persistent check engine light and power reduction.
2006 M1083 A1R C7
It started with an intermittent check engine light only at max speed/RPM. It seems like the ECM may have since derated itself, and while the check engine light no longer appears, there is significantly reduced power. The only code I can find has to do with boost pressure - 102.7.
Am I on the right track? Any other ideas?
2006 M1083 A1R C7
- I stated by checking the wastegate actuator. This seems to be function properly - VIDEO.
- I then checked the operation of the wastegate on a test drive and it barely opens. VIDEO - you can barely see it move. Perhaps because it's derated???
- Checked boost pressure. It's only producing about 13 psi. VIDEO
- I haven't been able to locate any air leaks in the charged air cooler or associated tubing.
