Introducing myself
CycleJay
Marietta, Ga
Hello 1984,
Welcome to the site..
And I wish you good luck with your M1009.
I have a 1985 M1009 myself. So if I can help you, just ask.
And if I am capable, I would be glad to help you.
If not, I will let you know, and maybe refer to something that could.
My best advice right now though, is to study the Technical Manuals (TM's),
for that vehicle so you can learn it, inside and out.
And feel free to ask questions here.
Good luck, and good night,
CJ
1984M1009
Phoenix, AZ
If you are in AZ why on earth would you buy anything with rust?
I had been looking for a while and they were all around $4,000 I got this one for $1800
I was looking at patch panels and replacement panels at LMC and will slowly fix most the rust The frame is very solid though
ralbelt
9
West Warwick, R.I.
Welcome. If you get some long bolts, about 8" you can slide the trans back while supporting the tail with a floor jack and replace the flexplate{flywheel}. Broken starter bolt can sometimes be harder than others just be patient.
My theory on my M1008 is if its rubber replace it, if its electrical clean it.
Have fun and good luck
1984M1009
Phoenix, AZ
My theory on myM1009 if its rubber replace it, if its electrical clean it.
What size are the bell housing bolts?
1984M1009
Phoenix, AZ
I got the broken starter bolt out I got real lucky
I bought a punch from harbor freight and it just bent before it even made a mark so I used the left handed drill bit and drilled two small holes one on each side and used the punch to spin it out.
I just need to get the bellhousing bolts out and the crossmember and the dipstick and she will be ready to pull
bkwudzhom
ga
Welcome from GA! Good deal on the starter bolts--be ABSOLUTLY SURE you have the bracket on the end of the starter or you will be replacing those bolts again!!
:deadhorse:Don't ask how many of us know this.aua
wallew
That's a sweet ride. Of course, we want more pix. But we can wait. Go enjoy the ride.
OH, do NOT use anything but the correct GM starter bolts. ASK ME WHY I SAY THIS. I learned that lesson the hard way (twice - but it was on two trucks during the same cold snap - each truck just dropped one bolt - then snapped the other one)
