I took the injector pump off my MEP-003 to find the IP locked up. When I took the IP off, I also found the shims between the IP and block are pretty rusted and chunks of the front shim are gone. I know these shims set the gear mesh and stay with the block, but I'm in need of new ones. Who can I get a shim kit from? It appears to be part number 147-0145, NSN 5365-00-421-9922. Who can get me this kit? I'm going to call Tom at Gulf Coast Trucks and Delks today to see if they have it. Perhaps I should aim for getting the master IP install kit part number 147-0305 NSN 2910-01-038-5250 just in case I need to change buttons?
Also, how do I re-set the gear mesh? I looked through the -34 TM and didn't see it listed. I am going to try to use a caliper to measure the total thickness of the shim pack but I don't know how accurate or possible that will be considering the highly degraded state of the shims.
