Is a Deuce "Whistler" Turbo on 6.2 worth considering?
JONNIE
WI
Hi all, I have seen the video of the Deuce turbo on the 6.2 but I can't seem to find any info on the build anywhere. I am about to get started on my own 6.2 turbo build and the 6.5 turbo seems the most convenient way to proceed but I am wondering if the Deuce (C?) turbo would offer any significant advantage. If so how much additional work is involved in the swap? I have spent a significant amount of wheel time in the M35s over the years and I can't help but wonder if it would spool up faster that the 6.5 turbo. I do realize one would have to remain at 10 psi or less boost regardless of what turbo is used. Any help would be greatly appreciated and of course if this has been covered elsewhere I apologize.
4,744
I'm planning to use this setup for a build. But it's not for performance. Only the sound.
The turbo isn't the limitation to power on the 6.2. They need more bottom end work.
JONNIE
WI
So, basically no gains to be had for the additional work with the exception of that phenomenal sound? Is there an exceptional amount of work to fit it to the 6.5 manifold? I assume the performance to be had with the Deuce turbo is not less than that of the factory 6.5 turbo...I hope?
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
A guy over on "the diesel place" did it, might be more details listed in his thread over there. He posted about it here, but not much detail.
JONNIE
WI
Thanks for the replies! I checked out the thread at "the diesel place" and it looks like building a manifold is in order so I'm going to go back to the factory 6.5 turbo plan for now.
Expendable
SoCal
This guy with his H1 removed his Muffler and Cat. (I am not condoning and or suggesting this). Just showing you what a Stock Turbo on a H1 with Stock engine sounds like with those removed. He's not the only H1 owner to do something like that to increase the turbo whistle coming from the exhaust.
reaper556
HOCKLEY, TX
A lot of work and cash for little to no gain. The 6.2 is turd no matter how you slice it and will never make power like the latter diesels. If you really need or just have to have more power drop in a 12v Cummins (not really cheap or easy) or a big block (a lot easier and cheaper it seems).
FWIW I have a another square body civy K30 with a 454 and it will far and away outdo my 1028.
nyoffroad
687
Rochester NY
It does sound cool but putting a larger turd blower on will take longer to spool up than a smaller unit on the same engine.
I think I said that correctly.
iatractor
19
SE Iowa
My dad said he loves the sound of my whistler. Reminds him of the first diesel tractors in the 1960's when everyone starting slapping M&W turbos on them. One guy told me to never change the turbo on my truck because he said it reminded him of the days when he was in the military. Said that when he heard that turbo, he knew they weren't going to be walking back anymore.
sochuck
So Charleston, oHIo
Ok...I love the sound and yes I will do this one day when school is out. But now the question? The install shown in the video showed mass butchery to the keep me warm and cool box, was that a choice or just because it is a mud rig? I know there isn't much floating around about this but perhaps someone has started this project...
