Oldsouthernboy
- 0
- 0
- Jacksonville, al
My M1009 tranny has been needing some work, I broke down and put her in the shop. A small shop in my area, a one man shop is very clean and very well kept. For the sum of 800.00$ he removed, rebuilt, the transmission, replaced the torque converter with a heavy duty one, used all metal parts, no plastic pieces, replace a u joint I did not know was bad, Replaced all the transfer case seals, checked and replaced the plastic shift fork with a metal one then adjusted the shifting linkage, Stated that the transfer case showed no signs of use, no case rubbing from the chain drive, all gears showed no wear. This was in on monday and picked up at noon friday, Said he was sorry it took so long he had three others to do. Soon he will get my M1028 to refurbish the transfer case and do tranny service.
