Is This One of Us? This Is Incredible to See
74M35A2
330
Livonia, MI
Is this a member here? This is just awesome to watch. Apology if already called out. At this level in the cab, you don't even need cup holders for a screw top 20oz bottle! Gives a new definition to liquid cooled - externally.
https://www.youtube.com/watch?v=kzsJZQi1FnI
It was a video a lot like this that made me buy my first MV, a 1974 M35a2, hence the handle. Here is that exact video:
https://www.youtube.com/watch?v=Np-AxPUaotw
dmetalmiki
2,028
London England
Thing is..I watch these videos, and it always amazes me that "they" don't run over, or crash into submerged bikes, motorcycles, cars, and other obstacles. I never hear them voice any concerns at all..I would MOST certainly be concerned. The boundaries of the roads can not be discerned even..Or damage to or collapsed pave. just my 1 1/2 pence worth.
74M35A2
330
Livonia, MI
Hope he plugged his fan clutch off.
Fan likely won't actuate for submerged engine. Doubt engine would even be able to maintain thermostat 180F operating temp, let alone reach the 200F fan trip. On an M35a2 they recommend to loosen the fan belt for your concern, but only because it is direct drive in that case.
Looks like a blast, wish I was with them (on the outside of the cab like Mr Camera)...in his truck of course. The image of water just pouring through the open windshields keeps replaying in my head.
Guyfang
23,906
Burgkunstadt, Germany
Only in the States! Only!! All my German friends just stand here before the screen and goggle like fish out of water! Just a couple of good old boys, helping out.
162tcat
46
Washington
i am sure wherever its parked now the drivelines are seizing up nicely
You old farts are no fun!! Both of my trucks were cheaper than a new ATV and are for work around the house and fun. I would drive my truck through that in a heartbeat! This is a hobby and like any other it costs money. Best case, lots of maintenance afterwards. Worst case, locked up engine. Either way tons of fun and quite possibly helping people out while doing it. You old farts enjoy looking at your truck parked in the shed with rodents chewing on the wiring. I'll be out driving mine and having fun!
1,131
re: maintenance
There are so many things that most people don't think about. That truck will never be the same. Gauges filled up with water, PCB filled up with water, blah, blah. It isn't just gearboxes to worry about
re: running over stuff
Ha, I always think the same thing.
re: snake
I didn't think of that and now I wish I hadn't. Thanks
NDT
6,486
Camp Wood/LC, TX
Glad to see they did not have the cargo bed full of evacuees. But they did have children with no pfd's. The National Guard and governmental first responders were under strict orders not to perform these kinds of stunts. Call in a boat rather than risk evacuees' lives.
Gunzy
66
Roy, Utah
The engine is probably toast after that. Am I the only one to see the water coming out of the exhaust stack?
74M35A2
330
Livonia, MI
Engine should be fine. The water out the exhaust is normal for the situation. The entire exhaust is liquid cooled in this case, including the manifold, so it is condensing all of the moisture that is in the exhaust pipe, continuously. Exactly same as when you first start your car in the winter and water drips out the tailpipe. but in this case, the exhaust pipe never gets warm, it is held cold, so the amount of water vapor that drops back into liquid is much greater. Same as how a distillation column works. Cool the vapor, and it drops back into liquid. Totally normal, and expected. Combustion reaction of hydrocarbons (process of adding oxygen) produces a lot of water vapor. It typically leaves the tailpipe in vapor form if the entire length of the pipe stays hot/warm (can form water drops on your hand if hand held over the pipe outlet for a short time at idle to demonstrate).
74M35A2
330
Livonia, MI
My take on the video is that I would not do it to my truck, for all of the reasons that you all list, but it is amazing that our trucks are capable of it. Yes, probably ready to scrap after doing so, but it can and will do it if need be to perform the task assigned or to get soldiers back home. Not too much other equipment has that capability.
teletech
209
santa cruz,ca
I wouldn't willingly do it to my truck unless lives were at stake.
Of course in those conditions of flooding there may be lives at stake. Just make sure the rescuers have a low probability of making the problem worse, after that you take your chances. Judgment, situation, and luck all conspire to make the difference between a heroic act and a stupid one.
Without being there, I'll withhold judgment about which one that swim was.
I will grant that they had an awesome time and that has real value in this life.
