Well........
Picked up the 2 M35's and the M101.
The M101 made it home. The M35's did not.
The one truck we used to tow with ran great for about an hour or so while still on base, but then developed what appears to be a fuel starvation issue. Runs OK then begins to loose power, will stop running and as you're coasting down while still in gear will re-fire most times.
We made it off the base about a mile and died in front of NSA on Rt 32. The NSA security did not like that too much. Thought they were going to lock us up and tow everything away. I made nice with one of the State Troopers and he let us work for a while. Removed the primary fuel filter and bled that and the 2 secondarys. In tank pump seems to work fine as we got good fuel flow after we removed the primary. Made it about another 3 miles with the intermittent shut off problem and decided to park the two trucks. Found a nice office park and parked them in front of a shop. Going to try and get them Friday.
Pictures will be added later.
Yes, I was a dumbass and forgot to take extra fuel filters. I'm assuming that's the issue, but won't take any offense to any suggestions and berating on not doing it right. Honestly, it's the first problem I've had.
Let the flaming begin.
Don
