KY Recovery pickup QUESTION
bc35339
Mt.Washington KY
I will be getting my Deuce soon from frankfort , its about 65 miles from home.
I think the fuel pump in the tank is bad becouse It wont start unless you use starter fluid but when it starts it seems to run fine (I havent drove it but it idles fine and moves forward and backwards fine) I let it run for about a hour. After the air pumps up and you shut it down and turn the accessorie switch back on you can not hear the fuel pump at all. But it will start back up so I figure the fuel lines are primed. But I THINK that after it sits awhile it will need starter fluid to start it up.
THE QUESTION IS.
Do you think the tank fuel pump is the problem?
If so can I drive it home (65 miles) without the tank fuel pump working after started with starter fluid?
I know very little about these trucks and only asume the tank pump isnt working due to it not starting at first with out starter fluid and not being able to hear the pump with the accessorie switch on and air tanks full without the truck running . Should i be hearing the pump??
Bryan
m16ty
211
Dickson,TN
You can hear the pump running if there is not alot of noise around. Under the cover on the pump there is a fuse. I'd check that first. They seem to run fine without the pump working after they are started. Could be other things that make the truck hard to start but I'd check the pump first.
DieselBob
13
Arnold Maryland
Mine ran fine without the intank pump running. Started just like normal also. Didn't even know it wasn't working until I went to bleed the fuel filters and nothing.
greenjeepster
9
Southbury, CT
You can only hear the fuel pump if you are standing by the tank. A bad pump should not impact starting. I would guess dirty fuel filters or a check valve is stuck open.
WTFandoffrd
mt washington kentucky
Sounds like a fuel pump muffler bearing of some sort, I would take it over to to Bruce at WTF and off road and see what he can do with it. He seems to be some kind of guru when it comes to this kind of stuff.
greenjeepster
9
Southbury, CT
More info on the check valve please.
What and where is this?
There is one at the bottom of the fuel pump, it is called a foot valve and it keeps the fuel from draining back into the tank. That is probably the most likely one as dirt can get sucked into it and hold it open. If your fuel pump is bad replacing it will fix this valve or you can try and flush it out.
