NormB
- 72
- 48
- Cloverly,MD
I mentioned this in the other thread on “MEP 802-803 filters”
The third stage filter (just before the injector “tree”) leaked. A lot.
Fast forward to sourcing new seals, cleaning out about a gallon of spilled fuel (really really), and the thing STILL leaks.
How hard is this, anyway?
There are TWO small gaskets, but the kit supplied by Wix only comes with one, plus the large flat ring for the top of the filter to the housing.
INstructions say there are TWO #3 washers. So I put the new one in the bottom, and it sits below the bottom of the bowl - no washer contact.
Reused the old one which sat about a MM proud of the bottom of the bowl and was still pliable - put everythign back together, guessed at torque (about a 1/4-20 bolt, figure 8 Ft-lbs, about hand-tight), turned to prime, fuel came out.
And yes, I used a NEW gasket for the TOP of the bowl, greased into place.
So what’s the correct gasket for the bottom?
Anyone else having this issue?
