LED light bar with folding windshield
Apex02
Tx
Ive been searching all over to find an LED light bar(or a couple led flood lights)for my m998a1 that will still allow me to fold down the windshield when driving. this will mainly be used as a ranch/quail hunting vehicle so the ability to fold down the windshield is appealing. anyone have any ideas?
Bravojmc
Palisade, Colorado
It would be easy to make one from L shaped aluminum attached to the windshield frame on the front, so it would go up past the top and back over the top of the windshield. Then mount a straight led bar on top...
Or just mount here and not worry about the windshield mount
Action
1,557
East Tennessee
The 2 snubbers at the top of the windshield stick out a couple inches. You can just about mount anything on the w/s frame that doesn't stick out past the end of the snubbers. Then, when the frame is folded down, the snubbers hit the hood first.
NormB
72
Cloverly,MD
I installed this: https://www.amazon.com/gp/product/B00UESXQ8Q/ref=oh_aui_detailpage_o04_s01?ie=UTF8&psc=1
Just above the winch on the winch/bumper plate. Brush guard clears by about 1" no problem. Light may be a little low for your needs, but you could always make a bracket and bolt it onto the windshield frame so it (they, or one of the longer ones) is out of the way, or use truck flood lamps bolted to an "L" bracket (it'll need a pair of rivnuts each) holding the lights ABOVE the frame/rooftop.
I don't have access to my pictures right now to show how I mounted it (drilled two 5/16 holes, IIRC) after testing fit/placement with c-clamps.
Apex02
Tx
How effective are those 2 flood lights in the grill? Are those the mrap flood lights I've seen on ebay?
Bravojmc
Palisade, Colorado
They are copy's of ARB lights. They are VERY BRIGHT!
Truck-lite LED headlights on low beam.
9" LED lights and the lights need adjusted up still.
Picture does not do it justice!
DLJIII
Bemidji, Minnesota
IMG_20170730_013633_581.jpg My light bar is not a driving light its an 911E or EP arrow stick but, it does not get in the way when I had the windshield folded down. It is only an inch or inch and a half deep and I believe you can order any color and color combo you like. Patterns are built right into the light but you can hardwire them to a certain pattern or steady. I wired my pattern for full flash and then the old rotator style pattern which looks pretty cool compared to the more modern patterns. If you cant find an all white color, you can find a local shop to change out the LED heads, they are the micro older gen leds so they are cheaper to buy and easy to replace. I replaced four of the twelve in my lightbar, there were two pairs of red on the right and two pair of blue when i pulled it out of my old cruiser. So, it can be done and cheaply. I bet these previous models of 911 lights are cheaper than they were new now that they are technically out of date. Just an idea.
