- 5,611
- 2,916
- 113
- Metairie/La (N'awlins)
I purchased one used LED taillight by trucklite that is allegedly working. The old composite light had 4 wires. The new one has 5. I connected all 4 wires and no lights, the 5 th wire was marked ground with no number so I grounded it and no lights. No marker, tail, turn- nothing.
I do have the newer style flasher with the newer style plastic turn signal switch and a standard 3 lever light switch. Can you only have led on one side? It this light toast or is there something else to it?
Does the "extra" wire marked ground supposed to be used also?
