lmtv 1078a1 brake lights stay on!!!
ironlung80
warwick ri
when you turn on the truck and air preasure builds up brake lights come on and stay on.
does anyone know what the cause of this issue could be?
Scar59
41
Mt. Eden, KY
A little trouble shooting will help; are the brakes actually engaged? Treadle valve (brake pedal) bypassing (hissing)? Find the brake light switch and meter it out. Most likely the pressure switch.
Suprman
680
Stratford/Connecticut
Air could be leaking thru but I would check the switches and wiring. You can use an ohm meter and see when the switches close with the pedal depressed or with air pressure.
Gunzy
66
Roy, Utah
Does the truck have a trailer brake handle? If so make sure it isn't applied, even slight application will turn the brake lights on.
