Actually, looking through that link more carefully it looks like there's either the wrong wording, or a loophole that may apply to the LMTV.
Class C doesn't apply if you're not hauling people or hazardous materials.
Class A would apply if your trailer is 10,000 lbs or more GVWR.
Class B, by using
GVWR it changes the whole thing to not apply to a <26,001 lbs. LMTV towing a trailer that is less than 10,000 lbs. Perhaps they meant
GCWR. You would need to call to confirm, or better: look up the statutes.
They also reference a Class D but do not define it here. I believe they mean a normal passenger car license (which is class D, IIRC).
Class A includes
- Tractor trailers
- Any truck and trailer combination with a gross combined weight rating (GCWR) of 26,001 or more pounds – provided that the gross vehicle weight rating (GVWR) of the vehicle being towed is more than 10,000 pounds
- Any vehicle in B, C or D categories, if you have qualified for the proper extra endorsements
Class B includes
- Any vehicle with a GVWR of 26,001 or more pounds
- A vehicle with a GVWR of 26,001 or more pounds towing a trailer with a GVWR of less than 10,000 pounds
- A bus with a GVWR of 26,001 or more pounds designed to transport 16 or more passengers (including driver)
- Vehicles in Class C and D categories – provided you have qualified for the proper extra endorsements
Class C includes
- Any vehicle with a GVWR of less than 26,001 pounds used to transport hazardous material (with mandatory placard)
- Any bus designed to carry 16 or more passengers (including the driver) and with a GVWR of less than 26,001 pounds
- School vehicles designed for 15 passengers or less (including the driver)
- Any bus or vehicle used for hire and designed to transport eight to 15 passengers (including the driver)
