Locking Hubs M1009
Mrtom
Duesseldorf, Germany
good evening from Germany,
my name is tom and thats my first post here. i have already read other posts cause of hubs but i dont find the answer. since 2004 i am driving a 1985 M1009. and no i think i need new manuel locking hubs because in both hubs i have a brocken plastic space ring and its not possible to get these rings seperat. and cause of this its not possible to lock the hubs. so my question is can you tell me other kind of locking hubs i can take for my truck. i found the warn 9790. are they correct????
thank you for the help and i hope my english is not the worst!!!!!!!
tom ;-)
DokWatson
Wasilla, Alaska
tom ;-)
Yes those will work. There are other brands available, but they all do the same thing [thumbzup]
bronconut
wisconsin
if all your doing is lockout then you wont need those. if your pulling the rotors ,you can replace the oe spindle nut with the kit you showed, but you dont need to. i replaced mine but only because i have the socket with the four tabs.
rnd-motorsports
Evart,Michigan
Welcome! Yes the warn number you listed will work! I like to use the superwinch hubs myself part # 400518 both will work and you do not need the nuts and lock rings to replace your lockouts! :driver:
wallew
bronconut,
The M1009 hub is NOT the same as the OE CIVY hub. NOT BY A LONG SHOT. It has a snap ring type lock washer and a key into a keyway that MUST be assembled properly or you WILL have problems.
If you have not pulled a hub all the way down to the spindle (yes, including the rotor) then you have not lived.
Mrtom
hey guys,
thanks you for your help. at first i will order the hubs without the "spindle nut ........". can you tell me a shop where you order those things?
so, its late here and i must wake up at 4:10. have a nice day
Tom
rnd-motorsports
Evart,Michigan
Any auto parts store will be able to get them for you and most cases what ever brand you want I like the superwinch but warn hubs are good. if you cant find them neer you you can get them from places online like summit racing .com and many others :driver:
hoplite666
Fairfax VA
Have the superwinch hubs always used c clips and not snap rings on the shaft? Just installed a set and thought that was a bit odd. I know the function is the same but a full snap ring seems more reliable.
donalloy1
Martinez Ca
rnd-motorsports, getting a compatability warning on Superwinch 400518? Will they work on my O9 OEM axle? Thanks in advance. DMLII sends
dmetalmiki
2,027
London England
Welcome to the site. Do you know tobias from your area who completely rebuilt a wartime jeep from the ground up, and drove it to the U.K. to attend the War and Peace show twice. He is a member of steel soldiers. I will p.m. his email to you.
