Locking hubs
Rich Johnson
San Diego CA
The bearings on my front left wheel went out and took my locking hub with it. Blew the insde of it apart.
Im having trouble finding a locking hub for the truck. The couple places I know of that I go for parts dont have them.
Has anbody got a source for CUCV parts or just got an extra hub assembly they could part with. All the civy places want to sell me a set for way too much.
1,808
Is the outer ring and plastic actuator OK? I may have the internals for one hub. This isn't an M1009 is it?
Rich Johnson
San Diego CA
Its a 1008a1.
I am not sure if the whole external half is good or not, but the internal part that goes behine the snap ring is what sheared apart. Sears put it back together and I just have the broken parts in a bag. The cap is screwed on the outside just fine. I havent had the truck long enough to have looked into the hubs so I cant picture the whole set up.
I would think that I should just get a whole inner and outer locking hub assembly.
wallew
Rich,
WARN should make a replacement hub for you. I can't tell you where to get one in your area, but I'm SURE you can do an internet search and come up with several retailers.
DokWatson
Wasilla, Alaska
The hubs aren't CUCV specific, you can get them just about anywhere. Hubs aren't cheap, warn premium hubs are 220$ a set. Might as well do it right, replace both sides so you don't have some cobbled together axle.
Rich Johnson
San Diego CA
The truck is breaking the bank. I just want one stock hub to put it back together. Im tired of going broke on it right now. If I could keep this truck running then I can eventually fix my m38a1 carb and get back to getting my m37b1 on the road.
ODdave
40
lansing michigan
find a ford with a TTB dana 50 in the junk yard, you should be able to get the pair of hubs for far less than $50, slap some black paint on them and be on your way !!!!
