If you are doing the driving, you could winch it on a small triler, if you need to rent one, Uhaul has double axle trailers. They take the weight. With the 65" height, be sure to chain it to keep it from tipping. Yes, thats a long haul.Be careful
I dont know what a trucker would want, but I imagine if you had the time it would be cheaper to have your own trailer and drive it yourself. The mileage on the rental could kill you.A trailer for 1K you would get alot of use out of and a good single axle trailer with the 15" tires would hold the weight, and it would be yours.You may be able to find a used one with the two axles for a grand and that would tril even better and take the weight better. Check haulers on "Yesterdays Tractors " site in the left side column. Contact them, maybe someone there can give you an idea what it would cost to have it hauled for you. If thats the way you need to go.Good luck.
