GFrost Roadkill
- 0
- 1
- Amery, WI
Fellas. I just moved my heavily modified 5 Ton M 818 from Wisconsin to Colorado on a 53' stepdeck. When it landed in CO I needed to move it three miles up the mountain on a Jeep trail. During that operation I noticed I was spewing coolant and I believe it was coming out the Petcock that feeds coolant back to the reservoir from the Manifold.
Truck runs fairly regularly not under load at about 200 degrees. Does that feel right at idle and getting up to 220 degrees under load?
Have you guys seen the Petcock in the picture leak before? Is this common?
What process do you use for refilling coolant system to be safe? I am assuming we fill reservoir and let it pump it through the block out the large hose on the bottom of reservoir and then back up to the return hose which seems to be the source of my leak.
When I "open" the petcock is that all the way in, (CW) or all the way out (CCW)? When I crack it a 1/4 turn CCW it spews coolant out the top?
If indeed that is my system leak, where might you suggest I buy a new one to swap it out?
Thanks for your insight and being a great community with a common interest.
Greg
Greg
