I've been checking all my grounds and going over all the wiring for the GP system. In the Electrical section of "CUCV Helpful Threads", Electrical Ground Locations, it states this: Diagram E-3 - Main Battery Ground - 2 gauge black from Negative Term Board behind rear battery - attaches to the front right frame.
I cannot find a 2 AGW ground to the frame. Is the ground on diagram E-3 actually to the bolt on the rear passenger side intake? The diagram does not state where the actual ground goes but, other figures show it goes to the same location as the body ground strap and fuel filter ground on diagram E-2.
I really appreciate the work that goes into the the helpful threads and all the help I have received but, as you can see, I am confused on that one only. Everything else has been spot on in the Electrical Ground Locations and the Trouble shooting guides on the GP system.
