Losing Air Pressure
Russ Knight
1,054
Perry, FL
I'm losing air when sitting with the service brakes applied. Leaking brake diaphragm somewhere?
captcarc
Canton/TX
Thanks to Wes, problem isolated. It is the brake pedal valve assembly. Ordered a new one today.
I lose 20# of air pressure, out through the engine intake, every time I press the brake pedal. Did replacing the brake pedal valve assembly at the brake pedal fix the problem? Where did you buy it and how much? Thank you!
