lots of smoke out driver side exhaust on startup
84cucv1ton
New Jersey
good morning. Just realizes the other day. Truck starts pretty good. Glow plugs are about a year and a half old. Injection pump has three or 4000 miles on it. Injectors have maybe 1000 miles on them. Passenger-side exhaust has just about no smoke. Any ideas? Thanks
JVK12280
W. MICHIGAN
I had the same thing happening, when i checked it out a glow plug wire had wiggled off rear glow plug drivers side.fixed connector and plugged it back in, no more white smoke cold.
Keith_J
1,318
Schertz TX
The connectors are the weak point of the system. They are brass or some other copper alloy and eventually lose their tension. Dirt can enter, causing higher resistance which causes heat and starts the vicious cycle.
The blocks can be taken off the connectors with a small awl, then the dirt can be positively removed. Restore the clamping tension by carefully bending the connector, then reassemble.
MT4222
Plymouth/MI
I use ac60 glow plugs. I have a manual glowplug switch and i cycle them twice for ten seconds each with a 5 second break in between.
Hasdrubal
Vancouver BC
I've used AC60's with great success for 8 years, on my second set. With the AC60's you can burn them for a full 20 seconds, withought the 5 second delay. Thats when they reach their maximum temperature of 1851 degrees centigrade. Though I find 17 seconds is enough on the coldest days. I do use a shorter time with a 5-10 second delay between burns during the afterglow cycle. I think the old school plugs (AC13,11,9 etc..) were the ones which would swell easily so thats where the pause between cycles would be warranted. Here's the temp charts for your perusal.
