Lunette Ring to 2 Inch Ball Adapter
maddawg308
747
Front Royal, VA
It's a very neat idea, and well executed, but I'm with the last two guys, getting a pintle hitch for the truck side is easier. However, if you just wanted to build something different and new, you succeeded!
jtpasto
Salmon, Idaho
Ball Adapter
This ball adapter only works on a M101A1 (no surge brakes).
The second question. I use a pintle receiver hitch that has the NATO connector installed (see attached pictures) when I pull the trailer. The ball hitch is for others if they barrow the trailer.
blue_mongoose
appleton wi
anybody setup something going the other way? My powerwagon has a pintle setup welded to the truck. I've been trying to fab an adapter that would allow a 2" ball to fit on it.
dodgedougak
Joseph, OR
I have a pintle setup that has a 2" ball as the bottom part of the C shape and a regular pintle type hinged top piece. You just lock the top piece up and use it like a ball hitch, drop the top and it is a pintle hitch. It bolts on in the same pattern as the regular pintle, or you can bolt it to a piece of square receiver stock with a flange welded on the end. I have found them at any good industrial hardware store.
