My m1008 had a engine miss, and then the fuel shut off switch stopped working, so I took apart the injection pump and found it full of metal filings. Changed the pump with a high quality rebuild, new lines, new injectors, replaced the fuel filter base/filter, new golow plugs. Bleed the system out.
Engine runs awesome, no more mis, lots more power no more black smoke.
However still starts with what seems to be to much effort. Needs glow plugs almost all the time even when warm out. Starts easy when hot. Cannot understand what is causing the cold hard starts.
Also has a newer high torque starter, cranks fast.
Could this be a fuel drainback issue? any help greatly appreciated.
thanks
thanks
