Jersey4x4
- 1
- 0
- Absecon, NJ
OK I bought this truck direct from the gov. didi some minor repairs over a few monthe then finaly tagged it. I drove it and it was shifting so hard 1/2 and 2/3 that the back tires would chirp(NOT COOL IN SNOW) so I replaced all the vac. lines. Still shifting hard so I replaced the modulator with a TM50 from standard which is a direct cross from the PM number and it looked totaly different from the old one and now it shifted way too soon but still hard so I adjusted the modulator to get the shift points correct and it was at the right shift point but still hard. I replaced the vac. pump now the funny part, it shifts like a wet sloppy sponge at when heavy on the peddle almost like it is gliding into gear. so bad you dont even feel the shift, but it shifts ok at slow granny driving. I replaced the TPS on the IP and no change. Next day fired it up let it idle down and warm up went to drive and it hit 35 in first then went to second and almost instantly went into third but the 1/2 shift was a wheelie making shift. so I droped my son off at school and while I was driving I noticed the shift points dropping and loosening up to the wet sponge shift again. I even added a vac. canister for reserve vac. and it did not help. I can not find the vac. modulator or TPS adjustment procedure in the TM so that might help but this thing is driving me crazy. Oh yea if I manualy shift through the gears it is absolutly perfect.
And it wont down shift to first unless you get almost to a complete stop like baby crawling speed but if I manualy put it in 1 it is fine. Any help would be great and a copy of the TM on the adjustment procedure would be a real help or even a manual number and page number. Thanks alot
