viking76
- 16
- 3
- Sandy Eggo
I did a thing! Probably old hat to most but it was new to me. So here it is in case anyone finds it useful.
Cheers!
Do as you will but that is a poor example of replacing the oil cooler lines. The clamp on the fan shroud that holds the cross over tubes is missing. Common issue and they will crack from vibration. Also the bracket on the rear manifold studs is missing and thus the oil cooler lines not staying in place where designed to stay. I changed an engine in the past because the oil cooler lines wore thru against the brake reinforcement on the firewall. It may sound silly. But jack it up and remove the left inner fender apron to get great access to that area. The inner fender apron needs some TLC anyway. Maybe even a replacement. Good Luck. I enjoyed watching the oil drain. I would recommend doing it right the first time and drive on. What was with the trans cooler completely bypassed. Not the way it is done. Have a Great Day. No Hacking. Happy 4th of July.I did a thing! Probably old hat to most but it was new to me. So here it is in case anyone finds it useful.Cheers!
Looks like some nice lines! I had mine repaired pressing on new hose,,, probably should just replace them entirely...I have seen the cooler unhooked from the radiator before and it is usually a leaking or low flow cooler inside...the cooler hooked up now hopefully is a big one that has a thermal switch inside...they allow only some of its core used when the fluid is cold and opens up the entire core once warmed up...I prefer the radiator style ones not the big tube ones....not a huge deal if you don't get cold where you are though!I did a thing! Probably old hat to most but it was new to me. So here it is in case anyone finds it useful.Cheers!
You shouldn't need the external trans cooler then...who knows why they unhooked it...the one in the radiator should be fine! 400s typically don't get to hot plus a pretty tough one...I saw you may put a temp gauge on the trans too...be fun to see what you get...I've been on the lmc site a good bit...I had a local company replace the one hose for a decent price...took a while though so I may just order the next one.@cucvrus Thanks again for the info. That is a negative on securing the rear of the oil cooler lines. I am going to send you a direct message about that rear bracket.
@WWRD99 Fortunately I am not in a winter environment, so no need to run any therm-controlled oil cooling. But I get your point. The oil cooler lines where from LMC Truck and they are NOT made in China. I forget if they where made here or Canada.... They seem pretty legit so I am happy with them.
OK. May I suggest that you thread the bolt thru the bracket and nut. That way you have a stud and can put the strap onto the stud and just put a nut on it. Also loosening the lines as you do the fitting will help. Them replacement lines are a blast. Some fit like a glove and others fit like Oj's glove. Good Luck. You got this.Well either my lines or the fittings are too long for the support bracket by about 3/4 of an inch.
@cucvrus , et. al. - Thoughts on using hangar strap instead of the actual clip? Or should I shorten the lines and re-crimp?View attachment 841983
Great suggestions. Thank you!OK. May I suggest that you thread the bolt thru the bracket and nut. That way you have a stud and can put the strap onto the stud and just put a nut on it. Also loosening the lines as you do the fitting will help. Them replacement lines are a blast. Some fit like a glove and others fit like Oj's glove. Good Luck. You got this.
