m1009 front ball joint removal
chaparral2j
ma
Can't take out ball joints on front passenger side, because of u joint in the way of getting ball joint press in there. wondering if anyone knows how to get access to them, thanks.
scrambled
Marietta,Ga
Strip off the caliper, hub/rotor,and spindle.
remove axle shaft
remove 1-1/8 nut on lower ball joint
remove cotter pin from upper ball joint
remove 1-5/16 nut on upper ball joint
hit knuckle on top with hammer to break the tapers.
watch out for falling knuckle
press out old ball joints and press in new.
reinstall knuckle
bguy193
Farmersville,IL
remove axle shaft
reinstall knuckle
Couldn't have said it better...............This is how it's done. [thumbzup]
