m1009 vibration
turbinesurgun
Lumberton Mississippi
1009 vibraton. 1986 m1009, when i accellerate the truck shudders and vibrates a little bit in the back. i checked universal joints but they are all tight. cruising speed is fine. any suggestions? thanks in advance
GM-M1008
Weatherly, PA
are your tires the same size ? are your tire balanced ?when was the last time you rotated your tires? are your rear tire wearing the same ? If you hit a pot hole or went off roading with the truck and hit something with you rear tires you might have a broken belt (not sure if you can feel it in the rear of the truck)
OL AG '89
9
Kingwood, Texas
Might be a transmission issue??? maybe slipping a little, while accelerating and then evens out once you get going. have you checked the trans fluid lately. check it see if it smells burnt...... or if it's getting discolored, brownish rather than RED....
turbinesurgun
the tires are all new probably less than 1k miles on em but this just started a few days ago. I had thought about the transmission too. gonna give it a service and see if it helps. thanks guys
turbinesurgun
Checked transmission fluid it was fine. So I put truck in neutral and climb under and shake driveshaft one time and figured out the problem. The rear u-joint is shot. When I checked it friday I had it in park and couldn't feel any play. With the transmission in neutral it loosened up and I knew right then what it was. Gonna pick up a u-joint and be back in bidness. Thanks everyone for your help and now I feel like a retard lol. I swear it is the original 1986 joint. It looks as if it still has the blue plastic inserts that hold the cups in.
