Oerthedge21
- 20
- 18
- Northford CT
Now that I've got my relay panel in and hooked up with help from some members here, I've slowly been trying to figure out the lights and whatnot, and have run into my next issue. The two switches in the box, labeled in the TMs simply as 3 way switches, are unlabeled in my truck. PO had painted everything inside truck, including the label plates above the switches. Anyone here have a truck that still has the labels printed? Also, is there a way to turn off the focus lights in the back? Mine stay on unless I disconnect the B/O relay or switch the service light switch to B/O. Isn't one of those switches in the box supposed to turn them off? Thinking I may need to pull the interior skins out again to check wires, would be a good chance to reseal the cieling and maybe reinsulate the box too.
