M1010 Lives
tomc
Jonesborough/TN
After some 2 years we finally have it running. Two fuel pump push rods that broke, we replaced it with electric. Made up new battery cables and it purrs like a kitten, well almost. Now just need to touch up the camo, get some good tires and find an antenna to retrofit for 2 meter and it will be ready to roll.
Tom in TN
tomc
Jonesborough/TN
Here are the pictures, though it is down now for charging problems. Hope to have it fixed by this weekend. Anyone know where to pick up parts for securing stretchers to the mounts PAOZZ 25022 37-0051 .STRAP,WEBBING?
Tom
Pops506th
15
Northern NV
Tom
Nice looking truck!
Good luck finding those straps. I've been looking for a while. I've got one set, but still need three more.
Let me know if you find a source
Scott
tvguy
Duluth, GA
Tom
Can you give me a little more detail on what you're looking for? I've got an ambulance "box" that I'm going to be scrapping soon and I may have what you need.
tomc
Jonesborough/TN
M1010 Parts
I have attached a diagram of the tie down straps need all 16 if I can find them. Also could use 6 litter straps (hold the person to the litter).
Also need the following if I can find them:
Cushion that goes on the litter pan (looks like a long brown seat pad)
Spot light bulb (checking locally to see if they can cross it)
Flood light bulb (ditto)
If can be found a complete hoist assembly
Antenna base and whip assembly
Down the road perhaps a workable or dead radio
Any information on the above is greatly appreciated.
Tom
270
akron, ohio
hey Tom, are these the straps that are attached to the inside wall? i know i have at least four, i believe, possibly more in the box of parts that came with my truck. and they will prob be coming out of there. currently one is used as a handy spot to hang my machet:mrgreen:. i have either 3 or 4 of the long cushions, and the aluminum gurneys. i will be taking the outside flood lights off, along with the complete a/c set-up, and possibly the rear diesel-fired heater. and also all interior lights in the back, along with the benches(at least driverside for sure, but itll be both if i decide to remove the heater) are being removed. give me a cpl days so i can check these items out on my day off, and then PM me. hopefully one of us, or a combo of members, can get you all the parts you need to finish you M1010!!
tomc
Jonesborough/TN
Nope, they are pretty short. Just long enough to hook over the handles of a litter and attach to the hook points on the litter tray, about 8" or so in length. They can be tightened up to secure the litter to the tray.
Tom
270
akron, ohio
TVGuy showed the same ones i meant, but let me look in my Box O' Goodies that came with the truck, and see what i can find. i think i may have seen some short straps in there before, but not sure. i'll let you know.
tomc
Jonesborough/TN
Just busted the wire going up the shaft for the roof mounted spotlight, will try and repair, but will be looking for a replacement part, perhaps the whole unit.
Tom
