May want to be careful about that. I think those wheels are hub-centric, and they rely on that hub in the middle to keep them properly centered on the axle. If the hole is larger than the hub on the trailer or the holes in the other rims, you might run in to trouble going down the road.Picked up a F250 rim and it fits. The whole in the center is slightly larger than the military rim, but it should work as a spare.
Thanks for the help.
It may be hub centric, but personally, I have several trailers and other vehicles that utilize the ford rim, so that's why I went with it. If you look at the older vehicles, or even smaller 1/2 ton trucks, you will notice that the rear wheels don't typically have a hub for the wheel to rest on. It is the lug bolts only that hold it in place & they have no problems what so ever, providing you keep the lugs properly torqued.May want to be careful about that. I think those wheels are hub-centric, and they rely on that hub in the middle to keep them properly centered on the axle. If the hole is larger than the hub on the trailer or the holes in the other rims, you might run in to trouble going down the road.
Someone correct me if I'm wrong here.
Also, it should be just a GM 8-lug rim... see if you can find a junkyard to trade you wheels.
